Proper PROM matching?
Old Nov 17, 2004 | 03:34 PM
PRoth's Avatar
OK. I've got my '87 Vette engine in my '88 IROC. Now I need a PROM for it, but I'm unsure which factory PROM to use. The car originally came with the 5.7 and 3.27 gears (PROM AKXX), when I got it, the owner swapped a 2.77 into it (which paired with ABYA).
So, to get to the meat of it: Is there a difference in engine parameters between AKXX and ABYA? I mean, I'm sure there's transmission variables, but is anything fuel related different? How?
And finally, will running a F-body PROM reduce the power of the '87 Vette engine? How much "hotter" was the Vette ECU?
Thanks,
-P
'88Z 5.7
Old Nov 17, 2004 | 04:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not sure which year Vette started with the aluminum heads. If the engine you have is iron headed then just use the f-body MEMCAL that matches your cars drivetrain.
If the engine is aluminum headed then the timing tables will be very much different. But a Vette MEMCAL won't run properly in an f-body.
RBob.
Old Nov 17, 2004 | 05:24 PM
PRoth's Avatar
It does have the aluminum heads. How much of a difference would it make?
-P
Old Nov 17, 2004 | 08:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
-P
Enough that you'd want to make some changes.
RBob.
Old Nov 17, 2004 | 10:26 PM
PRoth's Avatar
Ok. Would it have enough of an impact that the engine would get damaged? Would emissions quality suffer?
-P
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulaEngland
Sep 30, 2015 01:50 PM
rusty vango
Sep 29, 2015 02:44 PM
dusterbd
Sep 29, 2015 08:40 AM
