Commander 950 and Remote coil
Old Nov 19, 2004 | 03:43 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
I just purchased a Holley Commander 950 part # 950-101 for my car. Everything looks great cept for the fact that I don't see any connectors for the remote coil. Distributor harness is there, but nothing for the coil. Is there a seperate harness im supposed to have, if not, what has everyone with the 950 done to accomodate the coil?
Old Nov 20, 2004 | 02:56 AM
Dragroc's Avatar
ttt
Old Nov 20, 2004 | 06:09 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can the stock GM parts be used? There is a short 2 wire piece that goes between the coil and the distributor. This can be the stock GM part. Then the power and tach connector to the coil (heavy pink and a small white wire). This would be part of the stock wiring harness.
RBob.
Old Nov 20, 2004 | 10:32 AM
Dragroc's Avatar
Holley supplied this wiring adapter in the kit, goes to the distributor, then to the 950 harness.
http://www.holley.com/HiOctn/ProdLin...IA/534-47.html
I don't remember the stock GM connectors for the coil being seperate from the main harness, i'll have to go outside and check, thanks for bringing that to my attention!
Old Nov 21, 2004 | 07:54 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Yep, that adaptor goes from the C950 harness to the spark control plug on the distributor. There is a separate two wire "harness" that goes from the distributor to the coil. This would be a stock GM part that you should have if your car had an external coil originally. Then there are the coil power and tach feed wires that should be part of your car's wiring harness which will plug into the other connector on the coil. Unfortunately I don't have a good pic of this on my computer, or I could post it to illustrate for you. Basically the C950 harness will hook up to your distributor using the adaptor and you should have all the other wires needed as they are no different than stock. Hope that helped, good luck!!
-Paul
Old Nov 22, 2004 | 06:41 AM
Dragroc's Avatar
Crap, that kinda sucks... I was hoping for completely new engine harness wiring, and knowing GM that coil harness is discontinued. Well, I guess that's my only complaint about the Holley 950 so far. And for anyone that is going DFI and has a MAF 3rd gen, the intake snorkel for the speed density cars is discontinued, I was lucky cause only 1 dealership had one in stock, and it was 1 state away, they were kind enough to next day air it to me.
Old Nov 22, 2004 | 06:44 AM
Dragroc's Avatar
Hey Quadgoat, you got any engine shots I could look at?
Old Nov 22, 2004 | 07:30 AM
quadgoat's Avatar
Car: 1992 Firebird
Yeah, I've got a few I'll throw in here. I'll be home in a couple days for Thanksgiving and I can snap some pics of the coil wiring too if you want. When I put my EFI setup in I needed the power and tach wire/plug because I was converting to small cap/separate coil. I ended up going to a junkyard and snipping the wiring out of a Chevy pickup. So many GM vehicles used the same ignition setup that it shouldn't be too hard for you to find what you need, even if it is discontinued by GM.
A couple shots:
during installation:
up and running:
There are more pics of the install HERE
Let me know if you want pics of anything else. Good luck with the install!!
-Paul
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
ULTM8Z
Oct 2, 2015 01:25 PM
