C950 and knock sensor....
Old Nov 22, 2004 | 05:15 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
It looks like the ECU will read a knock sensor but where do I plug it in? The harness doesn't have a place for it.
Also, there is a sensor on the pass. side cylinder head that it doesn't look like it's needed. No hook up for it either. What should I do about that?
Old Nov 22, 2004 | 09:27 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
To hook a knock sensor up to the C950 you'll need this kit from Holley and a knock sensor to install in the block if you don't already have one. That accessory harness goes for about $37 from Summit and will allow you to use a knock sensor with the C950. I've been thinking about doing this myself as I think it might be a good idea. I don't currently have a knock sensor hooked up though and I'm not totally certain where I'd put one on my block since it's a '78 block and hasn't ever had a knock sensor installed in it. As far as the sensor in the passenger side head, that is/was the location of the switch for your electric cooling fan. Hope I helped, good luck with the C950, it's a pretty powerful tool!!
-Paul
Old Nov 23, 2004 | 08:03 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Thanks a lot. I have my fans on a switch so that eliminates another wire. Good to know. I can always hook up the knock sensor later, thanks for your help.
Old Nov 23, 2004 | 08:11 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
What parts are included in that knock sensor package...anyone???
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
