ID Chip & Info
Old Jan 6, 2005 | 11:49 PM
89 TTA #901's Avatar
ID Chip & Info
I have a aftermarket chip from my 87 GTA here is what it reads
Corv. Para.383
87F-A4-410
F455.CP2
Any info on this chip would be a great help
Who makes it ?
What injectors ?
Timing ?
Thanks Jim
Old Jan 14, 2005 | 09:58 PM
Anyone ????
Old Jan 15, 2005 | 05:52 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: ID Chip & Info
Most the folks around here burn their own, the odds of someone having the same chip as you're wanting info on are min.. If you get into doing your own, then you *might* be able to read it and figure out what you have.
Old Jan 15, 2005 | 08:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Moved. . .
RBob.
Old Jan 15, 2005 | 09:20 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: ID Chip & Info
Corv. Para.383
87F-A4-410
F455.CP2
Who makes it ?
What injectors ?
Timing ?
Thanks Jim
Just being obvious about it, looks like
87F Body ? Migt be $8D mask, 383 CI ?
-A4- is setup for 4 speed auto
-410 Might have been tuned for used on the car with 4:10 gears in it. (Timing and fuel tables, etc)
I don't know who uses naming conventions like that but maybe Formato's for the "F".
-.CP2- might be second revision of the tune for that customer.
Just guessing, really should suck it out and see what is on it.
Getting the moates Hdr1 would do it if and you could make any changes you need if the programmer didn't do any kind of scrambling of the data.
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
