I A T
Old Jan 16, 2005 | 08:53 AM
hookedon3gen's Avatar
Car: 88 camaro
Engine: 383 carbed
I A T
Will not having an IAT sensor pluged in give you a check engine light. I have a painless harness for a tbi and it has no plug for the IAT.
Old Jan 16, 2005 | 09:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: I A T
If the ECM is expecting an IAT and it isn't there, yes the SES will light. Not all ECMs use/expect an IAT.
RBob.
Old Jan 23, 2005 | 11:37 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Sounds like a truck tbi wiring harness. If this is for the 3rd Gen tbi, I believe they do use an MAT/IAT (RBob can confirm). Did you order the harness and did you specify the specific car?
If this is the ONLY limitation, you can pin the wire from the connector to the ECM and use the MAT/IAT.
