730 swap, now code 33
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Did the 730 swap on my Firebird and now I have code 33. High voltage at map=low vacume. My scanner says the map is holding like 4.33v constantly even at 4000 rpm. I tried the map sensor off my camaro and nothing changed, I thought maybe the new map was bad. Hunted for vacume leaks too, wondering if that was causing the low reading but none were found and vacume gauge said I was holding a steady 19. I checked all the wiring also and its all fine. Need to get it running fine so I can pull motor. Help please......
Car: check
Engine: check
Transmission: check
Re: 730 swap, now code 33
If it doesn't change the MAP ground may be open, or the ECM may be bad. The MAP get +5v from the ECM, ground to the block and ECM, then the signal goes to the ECM.
RBob.
Car: 1988 Formula
Engine: 355
I went through and checked all my connections. I have two map sensors and two 730 ecms. Tried both ecms and both maps and same results. Now the map is holding steady at only .78 v at idle and at like 4000 rpm. This is irritating.
