Accel DFI help needed
Old Mar 6, 2005 | 09:06 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Okay guys my friend recently purchased an 87 firebird, heavily modified 355 TPI with a Gen 6 Accel DFI computer. The problem of the moment is that his car is running very rich. Now I have a laptop, the software and the cable to interface but I don't know exactly what I should be looking to do. If anyone could give me a quick rundown on how to adjust the fuel pressure I'd greatly appreciate it.
Old Mar 7, 2005 | 05:17 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
do u have a fuel pressure guage?ihere's correct method for setting fuel pressure is to:
1) connect the fuel gauge securely with no fuel leak
2) start engine, let engine idle down to proper idle RPM
3) disconnect & plug vacuum line from plenum to AFPR
4) read your fuel pressure.
Stock fuel pressure should be at 43 to 44 psi.
With mods, you might want more than stock fuel pressure. Also, realize that the fuel pressure is set for the correct AFR at WOT, not for idle or for cruizin around. While idleing and cruizin, the ECM will correct the AFR to 14.7 as long as the ECM does not have to out of range on its correction factor.i have the emic manual for accel dfi let me know if u want it and i will e-mail it to u.i am no pro at tuning it but i have gotten light years better from the help of this board,so if i could pass along what i have learned then just let me know.
mike
Old Mar 7, 2005 | 05:19 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
by the way,those fuel pressure instructions are from someone on this board,i didn't write them just passing them along.
mike
Old Mar 7, 2005 | 07:41 PM
Car: 1990 Formula
Thats how I thought it should be done, but the guy who built the engine said we need to do it through the computer. I know I can change the amount of fuel across the map by a couple points if I can figure out how to open the file. I think I want to see if he does infact have an AFPR in the engine bay before I kill myself trying to learn this computer.
tazs2000
Jul 15, 2017 08:44 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
marcusaw
Aug 10, 2015 08:13 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
