Having problems starting car w/ MSD digital 6+ and C950
Old Mar 14, 2005 | 11:51 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Ok, looooong story short, I had spark and now it doens't look like I'm getting any. The C950 doesn't fire the injectors until it senses an RPM signal. Where does it get this signal? The dizzy? The ign. box?
One more thing, I picked up the TPI harness from holley as well. I cut out most of the factory harness to clean up the engine bay and avoid re-pinning the connectors for the new ECM. I still have the white wire and big pink wire connected to the fuse box that goes into the car. Those are hooked up to the ign. components. I tried looking at MSD's site and I was using these instructions http://www.msdignition.com/pdf/6%20series/pdf9.pdf , but it doesn't look like those work. Still no spark or fuel. I'm confused...
Old Mar 17, 2005 | 04:24 PM
Jack G Jr's Avatar
Hey you can try this question over at chevytalk.org in the efi section Doug Flynn the moderator works at Holley.He sometimes post on this board as well under Doug F.I am sure he can help you.
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
