Tech question
Old Apr 9, 2005 | 11:16 AM
BadBowtie88's Avatar
Tech question
Not sure if this is the right forum for this question, so if it's not, by all means Mods move it. I have a set of 30# SVO injectors for my car and I am trying to get a chip for it. A guy I saw at the track last weekend says he has a Jet stage II chip that he can't use b/c he went carb on his car. So the question is, will this work for the 30# injectors or no? I can get the chip for my worn pair of drag radials, but, I don't want to do it if the chip won't work. Any put would be greatly appreciated. Thanks in advance.
Old Apr 9, 2005 | 12:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is an injector flow constant setting in the PROM. If the Jet chip has the proper injector constant then it should work. Else it's a roll of the dice.
RBob.
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
gixxer92
Sep 1, 2015 04:32 PM
sailtexas186548
Aug 24, 2015 10:11 PM
redmaroz
Aug 16, 2015 11:40 PM
