Help on Proms
Old May 11, 2005 | 09:50 PM
trixxs's Avatar
Car: 86 Iroc Z28
Engine: 305TPI
Help on Proms
Ok, I know this sounds like a stupid question, however I have done numerous searches with no luck.
So could someone please point me in the right direction.
I have an 86 Iroc with a 305, I am doing the finishing touches on the 406 that I am droppin in the car next week. Finished installing the injectors and fuel rail, called Street and Performance to order a plug for the 9th injector that I am deleting. They told me that I would have to run an 89 computer because it is the only year camaro that ran a MAF without the 9th injector.
So the question, or questions
I was planning on having a local shop tune and burn me a chip to suit the new combo. Now S&P has left me in doubt. Are the actual computers different as in wiring etc, or can I have the shop burn me a chip with the actual computer I have?
Leading me to a few other questions Is the 89 computer a plug in and then add the custom chip, or do I have to do wire conversion similar to a SD set-up? In my searches I have found that some are 255 bit, and others are better. This is all foreign to me, So Im asking for help. The longer I try to narrow the searches down to be more specific the more lost I seam to get
Any and all help would be greatly appreciated
-Pete
Old May 11, 2005 | 10:02 PM
trixxs's Avatar
Car: 86 Iroc Z28
Engine: 305TPI
Sure enuff, as soon as I post I find something. Can someone please correct me if Im wrong. OK so I have a 1227165 computer and can have a chip burned for it to work without the injector
Old May 11, 2005 | 11:56 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Yes, you can use your old ECM just program a chip with $6E code its from a -89 TPI....
/N.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
