Knock Sensor with Accel DFI 6.0? Help!
Old May 19, 2005 | 12:19 AM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
Alright I'm overhauling here
I don't know if i have a knock sensor?
Where are they found?
Where can I find one for sale?
Thank you,
Meatwad
Old May 20, 2005 | 10:22 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Knock sensor is an add on to the gen 6. I believe there is a single pin connector for the knock sensor output. You hardwire in their kit, or adapt the original setup from your car (run 12v key on and ground to the module and signal wire to the sensor). Their kit is the same setup as the stock one (module/sensor combo from the mid 80's). The connector is near the distributor wiring. If you need, I can take a pix of mine.
L98GTA87
Oct 19, 2015 10:43 PM
85 Jimmy
Sep 30, 2015 07:56 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
e3pres
Sep 9, 2015 01:51 PM
