VSS on TPI really needed or not?
Old May 27, 2005 | 09:31 AM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
Ok from what I have read the VSS is needed for: Lock-up converter, EGR, charcoal canister, electric fan, Idle speed and fuel air ratio. (Did I forget anything?)
I am running a painless harness with a closed loop set up (no VSS).
I have made the following modifications:
-Lock-up converter controlled by Superior hydraulic kit.
-Running a mechanical Speedo
-EGR block-off plate
-Charcoal canister is a fuel tank vent only
-Electric fan is controlled manually
-Idle speed adjusted, works fine
The last thing is the air/fuel ratio. How critical is the VSS towards the CPU and fuel/air adjustments? With the above modifications, does the CPU have anything else left to make adjustments to?
I am trying to figure out what components the computer controls in regard to the VSS fuel/air ratio to find out if there is anything else that needs to be corrected, or is it fine the way it is.
IROCZ1989
Jan 24, 2016 03:55 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
