ecm location
Old Sep 3, 2005 | 01:02 PM
z28racer's Avatar
Car: 84 z28, 88 iroc-z 350 tpi,95 z-28
Engine: 350 tpi
Transmission: 5-spd
ecm location
can anyone tell me where the ecm is at on an 84 z28
Old Sep 6, 2005 | 12:33 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
All thirdgens came from the factory with the ECM mounted vertically behind the passenger side dash.
It's basically right behind where the map pocket is, if your car happens to have one. Once you remove the lower plastic trim piece (can't recall GM's name for it), you should be able to look up and see a plastic or metal bracket (most likely metal for your '84) about 6" wide that is held in place by two 7mm hex head screws. Remove those, and the ECM and bracket will drop down together.
If that description isn't clear enough, let me know, and I'll try to scan in a picture or something.
Old Sep 6, 2005 | 07:16 PM
z28racer's Avatar
Engine: 350 tpi
Transmission: 5-spd
thanks i found
skeltor
Feb 2, 2016 10:37 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Jlanz55
Sep 8, 2015 11:28 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
