2 Transistor ALDL Link Communication
Old Oct 12, 2005 | 09:54 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I built the two transistor aldl link found here:
http://www.andywhittaker.com/ecu/aldl_hardware_cont.htm
using external +12 for power, Pin A for ground, M for serial data.
Using Craig Moates v 8.52, I can't get the two to link up. It tells me there is some send receive echo going on. If I disconnect the M pin, it tells me the last address it read ... like 0E or FF.
Does this mean the two are communicating?
What is my next step to get them to link?
Old Oct 12, 2005 | 10:49 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
If using a 165 ECM, you may need the 10K resistor between A & B.
If using a '730, I don't know what to tell you, other than that it should work fine as-is.
Old Oct 12, 2005 | 11:09 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
How long does it take to connect?
Old Oct 12, 2005 | 02:24 PM
Dave_Jones's Avatar
It's almost instant.
I've seen some computers that were funny about the serial port. If you're in windows, try rebooting it in DOS mode, or even off a DOS boot disk. Or try another computer, if possible.
You might try running the ALDL test program from TTS.
http://www.ttspowersystems.com/adapt_cable.htm
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
