will a 5 speed computer work with an auto trans?
Old Oct 17, 2005 | 03:26 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
I have found an 88 350 TPI engine with the computer but no transmission. The original trans was an automatic, can this computer and PROM be used with an 87 700r4 that I have? Will I just have to add the wiring for the lockup function or does the PROM have to be programmed to lock up the converter?
Old Oct 22, 2005 | 03:33 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
You've confused me as to what you're trying to put into what.
In general, between auto and manual apps, the computers are the same, but the calibrations are different.
You do NOT want to try to run a 700R4 using a manual trans chip.
Old Oct 22, 2005 | 10:14 AM
Speedy Mike's Avatar
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
How about the other way around
Automatic chip with a manual?
Old Oct 22, 2005 | 01:30 PM
Dave_Jones's Avatar
At least it won't hurt the transmission that way.
Driveability may not be perfect, but people have occasionally done it that way and made it work in some cases. OTOH, I wouldn't say that's really the right way to go about things IMHO.
As to why this is, the throttle follower routines are different between auto and manual apps. Also, the code that controls TCC lockup in an auto isn't present in a manual bin, since it's normally replaced by the shift light code.
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
jharrison5
Aug 19, 2015 05:53 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
