Any trick to cross-referencing transistors?
Subscribe
Nov 4, 2005 | 11:37 PM
Anyone know of a trick to cross over a PN that I don't know about...like 'add a C' or 'subtract three from the number'?
This isn't in an ECM...it is in a PWM fractional HP blower motor on a '97 DeVille, but I figured I'd try to replace the bad transistors and caps before shelling out ~$250 on a new one.
Part Numbers on it are:
M(space)8699
R9634
Second one is
M 8699
R9635
So I assume the first one is the number and the second one is a date code. TIA
Reply 0
Nov 10, 2005 | 04:50 PM
You might try poking around on www.digikey.com or www.newark.com
Google search might also work as well, using 'transistor cross reference'
Reply 0
Subscribe
