Datalogging connection
Old Nov 22, 2005 | 06:04 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
Hi, on my s-series with a 1227747, i made the cable to start datta logging, i could never get it to work and finally, after i add a hard ground to the A terminal it works.
Well, thats good but it runs with TCC applied now. Is somthing bad in my aldl circuit maybe?
Also, not sure if this is related, but when i try to hood a scanner up, for it to work i have to hook up a TCC wire.
Is there a ground in the aldl hookup circuit or somthing? Im confused. I hate to do alot of wot testing with tcc applied all the time.
Old Nov 22, 2005 | 07:27 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
also, i didnt put the R2 circuit in, i ran a 12V wire from cigarette outlett.
Old Nov 23, 2005 | 10:39 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Ok, got it to work. I just ran a true ground like i said and of course i dont have to have it plugged into the A terminal, so that solved that problem.
Now, the current problem. When i start my truck in the cold mornings, it will slobber like its got a monstor cam but i found out its flooding out (pull a plug and it has gas on it, only one or two cylinders do this)
Well, of course that when i need the datalogging the most, but when its cool the computer doesnt send out any data. it slowly sends more and more as it warms up.
Anyone know about this one? Do i have to add any resisers or anything to make the computer go into a certain "mode"??
Any ideas or suggestions would be appriciated.
Old Nov 27, 2005 | 07:08 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
come on, anyone??
InfernalVortex
Apr 20, 2021 11:31 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
