programing prom
Old Jan 2, 2006 | 01:50 PM
327 iroc's Avatar
Car: ´86 Camaro IROC-Z/28 T-top
Engine: 327 (331)TPI
Transmission: th700r4
Axle/Gears: should be 3.73
programing prom
Hi!
Is it possible for me to program the prom when im scaning the ECM with the ALDL-kable??
Or can i just read it Nd take the prom out of the ecm and in to the pocket programer and use the other program??
Old Jan 2, 2006 | 11:48 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
its possible..
Use TuneproRT or TunercatRT
You will also need a USB and a serieport on your laptop........
/N.
I'm a member at several swedish forums if you need help in swedish.........
tune on
Old Jan 3, 2006 | 04:56 AM
327 iroc's Avatar
jaja, nu känner jag igen, från CCS & camaroforum.nu
English: (some wrong spellings)
Yeh yeh; now I recognise you, from the CCS & Camaro forums sites. CCS(CamaroClubSweden)
So the fact is that I cant program my prom just by using the ALDL kable?
I need to take it out/save the bin, and then erase it ant load the bin upp in another program Ex. TunerCat and then adjust it by locking att the results from the scaning??
Have I got it right??
Old Jan 3, 2006 | 05:15 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
yes..........
or if you have a romulator and a RT tuning software and a laptop with USB and Serie port. You can scan the car at the same time youre tuning it and se the results in real time............ But for "beginners" I thinks its best to scan, go home and analyse, burn a new chip and test.........
/N.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
ULTM8Z
Oct 2, 2015 01:25 PM
dusterbd
Sep 29, 2015 08:40 AM
Winchester1094
Sep 15, 2015 09:48 AM
