non CCC carb with CCC HEI ?
Old Jan 17, 2006 | 01:30 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
thanks
Old Jan 17, 2006 | 08:08 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Re: non CCC carb with CCC HEI ?
Originally posted by Fast68
anyone know if a ccc engine will run if the ccc carb is swapped off for a non ccc one but everyhing else left connected ?
IE: would the ccc HEI still work without a ccc carb plugged into the ccc harness ?
im thinking it should
At worst, I would think the ECM might set a code for a missing mixture control solenoid but everything else should work just fine. Obviously you need the HEI stuff plugged in...
Old Jan 17, 2006 | 12:38 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yeah thats what i was thinking
well i got the HEI back in and the wires for the HEI and the sensors other than the )2 one back connected and left all the carb wires dead ended
and it wqont freakin fire up, but its so close to firing though, but just wont do it
hmmm
what a pain
does anyone know about the black wires i the ECM harness running from engine controls to the ECM, why theres several and all the same, but separate
whats the deal with that?
should i connect them all to chassis ground ?
hmmm
this sucks
its actually a 229 v-6 engine, but its the same damn thing as a 4.3 or 305 or 350, 90 degree engine, same design, identical
i cannot for the freaking life of me find a non CCC HEI for one of these damn v-6 engines
or i would jut swap one in and be done and not have to deal with all this crap
thanks
Old Jan 17, 2006 | 12:54 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
What do you mean non-CCC HEI? Do you mean mechanical and vacuum SA HEI? I don't see what the HEI has to do with CCC, except that perhaps no vehicles came from GM with a CCC carb and non-computer controlled SA.
Old Jan 19, 2006 | 02:12 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
CCC is computer command control
EST is electronic spark timing
the computer controls spark timing and carburetor function
the seven wire HEI's
you know what im talking about..
dont play stupid..
im about 2 freaking millimeters from smashing and hauling this car to peoria shredder, because i am sick and tired of trying to find a non computer HEI for it
its pissing me off
apparently GM did not make a non CCC/EST 3.8L engine,
or 200cid, or 4.3L
i guess they are all CCC/EST
i dont know what to do
i think the car is screwed, because i cannot find what i need for it
its too bad cuz it ran great and drove good and didnt use any oil or leak any and has good brakes and steering and everything,
i think i give up
hum
thanks
sreZ28
Oct 22, 2015 08:21 AM
2012sergen11
Oct 13, 2015 07:38 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
