maf upgrades
Old Jan 26, 2006 | 02:09 PM
TownleyBA's Avatar
Car: 1987 Iroc-Z
Engine: 383ci TPI
maf upgrades
I have an 87 Iroc with a 383ci TPI engine. I am planning on installing the Accel DFI to gain some control in programming the engine to run more efficiently. I realize there are not alot of MAF options for the factory setup, but with changing the ECU and all could a LS6 MAF or something similar be used. The car tanked on the dyno at 4000 rpm, it should redline at 6200. I know that the program on the chip that is in the car now is not very good, but I am still running the ECU from the 305 TPI engine that came in the car. Any advice and info would be greatly appreciated
Old Jan 30, 2006 | 06:44 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Are you still using the stock chip in the ecu? I'm running a 350 with a stock maf sensor (without the screens) and I don't have any problem with hitting 6500 rpms. I have stepped up to a bigger throttle body and done a little work to the plenum and fuel rails. When I first went to TPI I didn't know anything about fuel injection and as long as I used the stock chip I didn't get anything close to what I wanted out of it. Superchip and hypertech didn't show much change either. The change came when a friend told me about 3rd gen.org and I found out about burning my own chips.
Anyway, I hope I helped. If not hopefully someone who has used other types of ECUs will reply.
Old Jan 30, 2006 | 07:06 PM
TownleyBA's Avatar
Car: 1987 Iroc-Z
Engine: 383ci TPI
whats involved with burning your own chip, in other words what kind of investment does it take
Old Jan 30, 2006 | 07:22 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
do you ever check out the DIY PROM forum? I think it the one above DFI AND ECM. Money-wise not counting the laptop, I ended up with less than $300, if I remember correctly. I'll try to get some of the basics together and send it to you. You can get everything you need from www.moates.net and tunerpro.markmansur.com . I am not the one to try to teach someone else how to do this, but I will help all I can.
BumpaD82
Feb 26, 2016 02:57 PM
amargari
Nov 10, 2015 02:09 PM
dbrochard
Sep 25, 2015 04:56 PM
Shane87irocz
Sep 22, 2015 06:21 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
