Coolant temp Jumps 100 deg.
Old Feb 28, 2006 | 08:29 PM
GSO-91Z's Avatar
Car: 1991 Z28
Engine: 305 F TPI - LB9 - GU2
Transmission: MD8 - 700R4
After startup, the engine runs idle for 3-4 minutes then the coolant temp reading in my data logger jumps about 100 degrees. It will go from 124 F up to 240 F in less than a second, but the console gauge is still showing below 150-160. This has been constant for the last two days.
I’m checking the sending unit and will replace it this week if needed but I wanted to throw this out to see if anyone has run across this before.
Thanks in advance.
Old Mar 11, 2006 | 06:21 PM
GSO-91Z's Avatar
Car: 1991 Z28
Well after replacing the Radiator, Thermostat, Coolant Temp Sensor, Coolant Temp Sender, and all of the hoses (upper, lower and heater). I still had the problem.
I flushed the system twice. I still had the problem.
I then removed all of the hoses, thermostat, throttle body, all sensors/senders and then started flushing each section one at a time.
Finally after I hit the section where the temp sensor was with water & compressed air whatever was blocking it broke free and water started flowing. Unfortunately, I could never see or find the material that caused the blockage but now I know if I every see this type of symptom again I know where to start.
I put everything back together and now it’s running better than before so I guess it was worth it. It also gave me a chance to clean up a few things while I was in there.
I just wanted to post a follow up for everyone.
Later.
Old Mar 19, 2006 | 05:18 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Thanks for the follow up, definatly makes sense that there was some sort of blockage or air pocket.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
