ECM...Do I need it?
Old Mar 13, 2006 | 12:28 PM
j dezzy's Avatar
Car: 87 TA
ECM...Do I need it?
I have a 91 firebird with a 3.1L that I'm swaping out for a carb'd 350 with manual choke...Do I still need the ECM or can I completely eliminate it?
Old Mar 14, 2006 | 07:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It depends upon what functionality you require. The ECM handles this:
fuel pump
fan
A/C
TCC
cruise control VSS signal
speedometer VSS signal
RBob.
Old Mar 29, 2006 | 05:36 PM
Demon355's Avatar
I'm doing the same thing except I'm going from TPI to carb. Torque converter lock up, how do I wire this up without the ecm? I've figured out the fuel pump already, but can that stay on all the time or once I get the motor running can I turn it off? I would like to know EVERYTHING there is to know about removing the ecm and wiring as I want everything I don't need gone. Please help, project starting soon.
Old Mar 29, 2006 | 06:02 PM
j dezzy's Avatar
Car: 87 TA
What are you doing fuel pump wise?
Old Mar 29, 2006 | 06:04 PM
Demon355's Avatar
Using stock intank pump and running either the Holley or Mallory 3-way regulator.
I need to know everything on removing wiring and the ecm as I'm throwing in a 355 carbed motor. PM or email me with all the steps in removing everything. I'm starting the project soon and don't want to **** anything up, lol! Thanks
PS, same goes for the trans wiring (if any), fuel pump, gauges, interior lights all that crap...
eagle_eyes
Apr 12, 2007 02:16 PM
