No communication with ECM
Old Feb 23, 2006 | 09:56 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ive got an '86 Iroc that I cant communicate with my computer. I have a Tech I to use. What do I need to look for other than opens in the wires from the DLC port and the ECM? The CEL light is burnt out and want to know if there is any codes.
Old Mar 30, 2006 | 07:00 AM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Check your ECM/fuel pump fuse, could be blown...I had asimilar problem ...Thought the ECM was dead...Check see if the fuse is blown...It is located on the inside fender close to the - ve battery cable..there is an inline fuse there...On my 88 it is located on the right side...On yours I think it is located on the left side fender well....87 and earlier the battery was located on the driver side in the engine bay
Old Mar 30, 2006 | 11:14 AM
Brent's Avatar
You don't mention if this is a CCC equipped car, but those require a working CEL bulb for the scan tool to work. The bulb is in series in the data line.
Old Mar 30, 2006 | 08:25 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
That fuse is good cause my guel pump is working and car runs fine.
Its a TPI 305. That might be why then, the bulb was blown or taken out I cant remember . Ill get a new bulb and throw in there!
Thanks For the help guys!!
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
