TunerPro or Win ALDL file to play with?
Old Mar 21, 2006 | 12:28 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I'm in college right now without my car. (Mines the 82, the rest are my dads). Is there a file I can download to play around with either TunerPro or Win ALDL to get used to it before I do the actual thing?
Also, what are my options for buying an ALDL cable and pluging it into my Video port in my laptop?
So far, I've found
http://www.geocities.com/steve3034/cables.html $65 shipped
http://www.aldlcable.com/ $39.95
Finally, can I use the ALDL cable for my 82 and my dads 90 and 91?
Old Mar 21, 2006 | 10:11 AM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
try ebay for the ALDL cable, i just bought mine from there and its real nice, and much cheaper if you find the right seller. or build your own!! its much cheaper!! and i bet you know someone at your college who can solder. when it comes to making it dont try and jam all the cable and wire into the 9-pin on the aldl site.....use your head and find a bigger "box" and attach the female 9-pin to it
Old Mar 21, 2006 | 06:58 PM
jms's Avatar
jms
Download TunerPro from the site. Also on the site are files you can use for practice. Just look around his site.
http://www.supportfitness.com/mark/tunerpro/
http://www.supportfitness.com/mark/t...ownloadApp.htm
http://www.supportfitness.com/mark/t...oadBinDefs.htm
jms
Old Apr 21, 2006 | 01:53 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Ruse Electronics - PCM Interface Cables $65 shipped
ALDL OBD1 OBD cable OBDI OBD2 engine codes $39.95
Check out moates.net. Craig makes a USB ALDL cable -- no serial port needed.
<b><u>CABL1 OBD1-Style ALDL Connector</b></u> [CABL1] - $30.00 : Moates.Net (CABL1 for 1982-1992)
You'll need the USB adapter too.
<b><u>ALDU1 USB-to-ALDL Converter</b></u> [ALDU1] - $50.00 : Moates.Net
Its $15 more than Steve Ruse for the whole setup, but onlike Ruse's, you get the AutoXRay-type connecter, so you don't have to do any splicing, just plug it in like a store bought scan tool.
InfernalVortex
Apr 20, 2021 11:31 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
