HEI tach reference pulse
Old Apr 6, 2006 | 12:56 AM
280Z28's Avatar
Does anyone know exactly how wide the HEI tach reference pulse is?
Also, to verify: it's a square wave that goes high (5V) once per cylinder, with a falling edge that occurs at 10* BTDC (after alignment with a timing light).
Old Apr 13, 2006 | 07:55 PM
Doctor J's Avatar
To be clear, the TACH signal in most L-98 type cars was taken from the coil
primary. The plug fires when the coil goes from 12 v 'conducting' to 'open'.
If you're talking about the HEI module ECM reference pulse (DRP) this may be
what you're looking for:
http://www.megasquirt.info/ms2/heiest.gif
It's from this site - look under the 'Ignition - GM HEI section' :
MegaSquirt-II - Advanced Electronic Fuel Injection Computer by Bowling & Grippo ©2005
The falling edge of the DRP corresponds to firing the plug. Reference pulse
duration looks to be about 50% duty cycle on a 7-pin HEI ICM.
Further notes:
For more discussion of the 'zero-crossing' reluctor trigger, read the application
notes for National Semiconductor's LM1815 chip. It appears to be similar to
the circuit that GM use on their VR triggers:
http://www.national.com/ds/LM/LM1815EP.pdf#page=1
HTH.
InfernalVortex
Apr 20, 2021 11:31 AM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
skinny z
Oct 5, 2015 06:23 PM
Hal87
Sep 26, 2015 09:26 PM
Damon
Sep 26, 2015 04:29 PM
