comander 950 green (fuel pump) wire
Old Jun 7, 2006 | 05:52 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
Ok so im lost here i got the comander 950 and i have figured out were all the wires go except the green one. The instructions say to hook it up to the fuel pump or a fuel pump relay but how do i do that? where is the fuel pump wire i hook it up to? i got a stock style in-tank pump and there are a few wires coming out the top of the tank do i hook it to one of those wires? ........... any help would be awesome! thanks in advance!
Old Jun 7, 2006 | 09:41 PM
Gary Anderson's Avatar
You might try asking here:
Chevy Talk - Chevrolet Forums: Viewing forum: EFI/Fuel Injection and Engine Control Systems
Doug F., the moderator, is a fuel injection engineer for Holley. I'm sure he can help.
Regards,
Gary Anderson
Old Jun 8, 2006 | 01:35 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
thanks i will give that a shot
Old Jun 9, 2006 | 12:01 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
If you have TPI, the middle relay on the firewall to the left of the brake booster has the same color wire going into it, splice it to that wire.
Old Jun 9, 2006 | 01:05 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
thank u thank u thank u
Old Jun 9, 2006 | 01:07 AM
to the right of the brake booster i mean (as standing in front of the car)
Old Jun 28, 2006 | 09:42 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
i would use the fuel pump that came with the kit. If you bought it that way. It's a high flow fuel pump and a external at that so no more dropping the fuel tank when you have a problem. YES!!. if not do what they said.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
