How do you determine base timing ?
Old Jun 21, 2006 | 02:56 AM
388's Avatar
388
Car: oldsmobile
Engine: 3.88
Transmission: yes
Axle/Gears: yes it has axles
I know its such a general question but i just need to ask it. I know theres many things like temperature etc that affect it but how do you figure out what is a base timing curve etc in a gen 7. Im clueless how to know where or what # to start at. ive been told LT1/4s like 15 ish degrees timing and elsewhere i hear 22-27. this is for idle. Do cam specs take part in this? Any info/help/tips would be appreciated.
Old Jun 21, 2006 | 12:07 PM
Z69's Avatar
Z69
Base timing is the value you set the distributor at.
Idle timing is CR and Cam dependent. A bigger cam will want in the 22-25 range at idle. But will still run at 15 to 18 too.
midge54
Sep 2, 2020 07:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
