Help - need pin diagram for engine harness
Car: 87 Turbo Regal
Engine: 3.8 SFI turbo
Transmission: 200 4R
I need to re-pin a harness, and I need a diagram at of the wires at the fuse block bulk head, and the small dash harness inside the car behind the passenger side dash. Car is a 1991 formula 350.
this is an example of the diagrams I need for the F-body:
Connector Pinout Diagrams
Can anyone help? Thanks!!!
Car: check
Engine: check
Transmission: check
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
If you can't find what you need from the links, I have
the service manual for a 90 Formula. I would expect
the connector diagrams to be the same. PM me with
enough detailed info, & I'll xerox & snail-mail whatever
you need.
kk
you need.
kk
