whats wrong with this picture?
Old Aug 1, 2006 | 11:45 PM
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
Transmission: 700-R4
ok anyone see anything wrong with this screenshot of datamaster hooked up to my car. I dont understand why its at 189 degree and still in open loop. Aside from that notice any other things that look off? I really dont know the ranges that the readings should be in. Any help would be wonderful.
Old Aug 1, 2006 | 11:58 PM
Car: 92 z28 25th
Engine: 5.7 liter
ok ....cant seem to find the best way to post the pic...photobucket is being a pain....
Old Aug 2, 2006 | 12:09 AM
Car: 92 z28 25th
Engine: 5.7 liter
http://i31.photobucket.com/albums/c3...gfnghjkghj.jpg
or that
Last edited by 92zcamaroperson; Aug 2, 2006 at 12:12 AM. Reason: Automerged Doublepost
Old Aug 2, 2006 | 06:25 PM
Gary Anderson's Avatar
If I'm reading correctly it shows 235 seconds running time? Roughly 4 minutes. If it was all idling its likely the O2 sensor isn't warm enough to function. Do you have a one wire O2 sensor?
Gary Anderson
Old Aug 3, 2006 | 12:39 AM
Car: 92 z28 25th
Engine: 5.7 liter
Yes.
I believe i have found the issue to be a broken egr solenoid causing a code 32. Hopefully that was it.
You can see on the bottom the spikes in the advance. Would the vacuum leak at the solenoid that i have cause this? It goes sporatically between about 16 and 20 and the numbers in between and sometimes up to 25, all at idle.
And is there something on the net that explains what all of this information means. For example in the upper right hand corner you have the green and yellow boxes with 1's and 0's. Where it says 1 and then a VATS FAIL....what does that mean?
New2Chevy
Sep 28, 2015 12:35 AM
sunbound
Sep 5, 2015 11:52 AM
chubsworth
Aug 26, 2015 02:34 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
LittleFranks
Aug 20, 2015 03:55 PM
