Chip and injector size question
Old Nov 6, 2006 | 03:05 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
I upgraded to #24 injectors over stock #22 should i get a custom chip or are they ok to run stock. Have a adj maf sensor that I leaned out and seems to run fine but wondering if more power gains from injectors could be had with new chip. Also have afpr set at 50lbs while running
Old Dec 19, 2006 | 10:01 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Are you logging data? Do you have a wide band O2 sensor? Do you know how to tune and burn chips? Simply adding more and more fuel will not necessarily make more power. It will certainly reduce your gas mileage
Old Dec 19, 2006 | 10:30 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
No i am not data logging yet. i just purchased the burn1 and am installing a hsr. i am going to turn pressure down to about 45psi and already burned a chip for arap bin with a 6e mask with egr delete and #24 injector constant not experienced enough yet to change fuel and spark tables but will once i get wb o2 and data log i will start playing
Old Dec 20, 2006 | 04:31 PM
Transmission: TH350
You don't really have to have a WB but it will definitely help. Your ecm is probably working overtime compensating... reducing the fuel that you are trying to add by increasing injector size and pressure...
The ecm is trying to achieve a value of 128 for the BLM which is the amount of fuel... the O2 gets a reading and the ecm determines if it is rich or lean then compensates accordingly. You have mechanically increased the amount of fuel so the ecm is sending what it thinks is less fuel to compensate for the richness...
You really need to start datalogging to see how all this works together.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
