730' Swap question
Old Jan 1, 2007 | 03:15 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
730' Swap question
This spring i'm converting to a 730'ecm from my 165'ecm.
The 730'ecm I picked up didn't come with a memcal.
I am using the Moates G1 Memory Adapter and i've been tuning the chips myself for my 165'ecm.
I was wondering if I have to find a 730' memcal and have it plugged in the G1 adapter or is that only used for limp-home or backup purposes?
Thanks.
Old Jan 1, 2007 | 06:19 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I think it has to be in there for limp mode only. Not sure, but tpiparts.net did have them new for 75.00.
Old Jan 1, 2007 | 10:40 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Have to have one.
Knock sensor stuff is in there among other things.
Cylinder select errors etc.
Old Jan 4, 2007 | 02:32 AM
Ahhhh ok. Thanks guys.
Old Jan 4, 2007 | 02:51 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You will get a code 42 if it doesn't see the 730 knock circuit info.
Old Feb 11, 2007 | 06:49 PM
Can I use a V6 730' memcal?
edit - nvm i guess you can't.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
