ecm- which 1?
Old Jan 6, 2007 | 09:41 AM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
ecm- which 1?
what ecm do i have in my 91 camaro rs? where can i take my car to have it tuned?
Old Jan 6, 2007 | 10:12 AM
smartman__007's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
Most likely the 1228746 with $61 mask you would only need it tuned if you did some MAJOR engine modifications like new cam, rocker arms, intake, fuel pressure, exhaust, heads, etc. Your best bet is to buy the equipment and do it yourself. Check the posts at the top of the TBI forum and start DIY tuning. Let's you change for free if you decide to change certain parts and need a retune, and you get a little closer to the inner workings of your car. Besides it's cheaper to do it yourself with all the help here.
Old Jan 6, 2007 | 05:49 PM
Car: 91 rs
Engine: 305tbi
would it work
would it work with a 350tbi or should i get one from a 350 car?
Old Jan 6, 2007 | 06:21 PM
Car: 1990 Camaro RS
Axle/Gears: 3.08
Well it might be more involved to swap a 1228747 ECM but i'm not sure. If it is a 350 TBI motor from a Camaro, Firebird, or Caprice, then i would swap in the 350 ECM. but Otherwise keep the 1228746 which is what you have and tune from there with more fuel pressure. Check the 305 to 350 swap thread towards the top in the TBI forum.
bamaboy0323
Aug 27, 2023 05:40 PM
mm92
Jan 20, 2014 02:45 AM
Onelastride89
43
Nov 29, 2011 11:23 PM
J0hn_J0hn08
Nov 22, 2010 02:38 PM
