GM Fuel Injection on a 1973 VW Super Beetle..need some help
Old Feb 12, 2007 | 09:20 PM
96LT4c4's Avatar
Car: 99 HOSS 6 Speed
Hi guys I haven’t posted here in a while. I am usually over at fullsizechevy as 94blazer383. But anyway, my dad and I have a little project on our hands. A 1973 VW Super Beetle with GM fuel injection. It came out of a 91 S-10 with a TBI 2.5 L 4 banger. ECM part number is 1227165 ASWY mask $83A, I think the ALDL data stream is A099.
I am using Tunerpro RT with an Autoprom. I have a .bin, .xdf, but my problem is with the .ads file. I am trying to make my own. Going off the A099 ALDL file and using my $0D A217 .xdf for my Blazer, I have the beginnings of an .xdf for the Beetle. I set up the command string, payload size, Checksum Cmd is checked, Master is checked, and Monitor is checked. I am not sure about the payload offset. My A217 file for my Blazer has a 4 there. How do you determine the payload offset?
I am able to connect to the ECM but I am not able to read any data, I just get all zeros. I have a few things added like TPS, RPM, and Engine Coolant….etc. I know this ECM came out in TPI Camaros, Firebirds, and Vettes. Just wondering if you guys might be able to give me some ideas on what I need to do to read the data from this thing. I don’t think I need the 10K resistor because the A099 says it’s an 8192 baud, and I thought that was only for the 160 baud ECMs. But I found an .ads file by Mark Mansur called “1227165-160baud”. Any help would be appreciated.
Here is some of the ALDL A099
DATA STREAM A99 SPECIFICATION
ENGINE USAGE:
2.5 L TRUCK TBI LN8 1990 S,T,M TRUCKS (VIN=E)
2.5 L TRUCK TBI LN8 1991 S,T TRUCKS (VIN=E)
DATA PIN : READ DATA ON PIN "M" OF ALDL CONNECTOR
BAUD RATE : 8192 BAUD BI-DIRECTIONAL
..PAGE
MODE 0 (RETURN TO NORMAL MODE)
ALDL REQUEST:
- MESSAGE ID = $F0
- MESSAGE LENGTH = $56
- MODE = $00
- SUM CHECK
ECM RESPONDS WITH NORMAL MODE MESSAGE *F97*
MODE 1 (TRANSMIT FIXED DATA STREAM)
ALDL REQUEST:
- MESSAGE ID = $F0
- MODE = $01
- SUM CHECK
THE ECM WILL RESPOND WITH THE FOLLOWING MESSAGE:
- MESSAGE ID = $F0
- MESSAGE LENGTH = $95
- MODE = $01
- DATA BYTE 1
- DATA BYTE 63
- SUM CHECK
6 COOLDEGA COOLANT TEMPERATURE, A/D COUNTS
DEGREES C = N*.75 - 40
7 COOLTSU START UP COOLANT TEMPERATURE
8 ADTHROT THROTTLE POSITION, A/D COUNTS
VOLTS = N*(5/255)
9 NTPSLD RESCALED TPS, 0 = 0%, 255 = 100%
% THROTTLE = N/2.56
10 NTRPMX ENGINE SPEED VARIABLE (RPM)
RPM = N*25
11 OLDRFPER TIME BETWEEN REFERENCE PULSES (MSB)
12 OLDRFPER+1 TIME BETWEEN REFERENCE PULSES (LSB)
uSEC = ([N11]*256+[N12])*15.26
..PAGE
13 FILTMPH FILTERED MILES PER HOUR VARIABLE (MSB)
MPH = N
14 FILTMPH+1 NOT USED
15 AD02A OXYGEN SENSOR VARIABLE
VOLTS = N/226
16 ALDLCNTR OXYGEN SESNOR RICH/LEAN TRANSITION COUNTER
Pics of the car
http://s105.photobucket.com/albums/m...uper%20Beetle/
Oh, the command I am using is.
ALDL REQUEST:
- MESSAGE ID = $F0
- MODE = $01
Old Feb 14, 2007 | 11:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I would try the 10K resistor just to see if it makes a difference. As for the payload and such search the DIY_PROM board and check the Tuning Guide sticky on that board. The sticky should have some links to threads that discuss setting up for scanning.
RBob.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
