How does DFI 6.32 calc. fuel?
Old Apr 25, 2007 | 01:49 AM
1fast97gsx's Avatar
I'm just curious as to how the gen 6 dfi calculates fuel requirements? Does it just go off of MAP / O2 sensor values along with tps? I'm having a problem running rich across the board, but all my sensors check out fine ( except for the O2 which I haven't checked ). The car used to run fine, but the plugs are all pitch black now and the car misses and jsut runs like crap. Does the DFI also have open and closed loop? Even under wot I'm pig rich, so if in fact it has both I should be able to rule out the O2 sensor given that. I appreciate the help.
Old Apr 26, 2007 | 01:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: How does DFI 6.32 calc. fuel?
The MAP, IAT, CTS, TPS, and RPMs all come into play in the fuel calcs for a typical SD system. If its blowing smoke and is rich across the board, the CTS and fuel pressure would be items to look at. If it was a high MAP issue, at WOT it would probably still be ok.
Bad misfires from ignition problems or lean issues can also turn the plugs black, but it wont be a heavy soot like running way rich, just a charcoal grey color.
Old Apr 27, 2007 | 02:30 AM
1fast97gsx's Avatar
I have a brand new cts anyways, so I will try that tomorrow. As far as the fpr ... I tried applying vacuum to it with a vacuum pump to see what it does, but it wouldn't hold any at all. I would assume if it won't hold vacuum, then it also won't open when the engine is pulling vacuum on it? Is there another way to test it with the car not currently running? I have the regulator off the car .... but it seems like that may be my problem.
Old Apr 27, 2007 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It may be that the FPR diaphram is bad, which will cause it to not hold vacuum (while testing), and allow fuel to be pulled through it while the engine is running.
With the regulator off the car, apply vacuum to the port. Then check if air is being pulled through the regulator from the fuel side. If so, it is bad.
RBob.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
marcusaw
Aug 10, 2015 08:13 AM
