What Aftermarket ECM's run your car using a Wide Band O2?
Old May 4, 2007 | 12:26 AM
Steve40th's Avatar
What aftermarket ECMs, such as DFI?, can utilize a wideband O2 all the time to control a/f ratio for better performance?
I think a MOTEC can, but I am curious if anyone has converted over to this type of set up.
Old May 4, 2007 | 02:01 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: What Aftermarket ECM's run your car using a Wide Band O2?
Megasquirt does. It can support dual wideband controllers which independently control each bank of injectors.
Old May 4, 2007 | 06:53 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
Nearly every aftermarket system available can use a wideband O2 sensor these days. The ones that can't perform that (basic) function are probably not worth using anyway.
Old May 4, 2007 | 07:35 AM
Toehead's Avatar
It certainly makes tuning easier. I know that in the megasquirt if you have a wideband all you have to do is create an AFR table, and the megasquirt will match it. That means you don't have to mess around with a VE table, which can be a pain sometimes.
Old May 4, 2007 | 10:25 AM
Steve40th's Avatar
Thanks. That sounds like something I would want, especially if I go old school car, 67 Camaro, with an LSx engine.
Old May 4, 2007 | 10:43 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Well worth the price of admission.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
marcusaw
Aug 10, 2015 08:13 AM
