No rpm readings
Old May 5, 2007 | 08:51 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
No rpm readings
Hi!
I have just installed aMSD 6al ignition box.
And the car runs but the rpm meter does not work after that,i have tried to put the old ignition coil back but still no rpm speedo.
Can the ecm have been damage?
Thanks for any replay.
Old May 5, 2007 | 09:09 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: No rpm readings
And one more thing,were does it get it readings from,the distributor?
Old May 20, 2007 | 05:14 PM
Crazy 84 Z28's Avatar
Car: 1984 Z28 Camaro
Engine: 305 H.O. 72,000 original miles
Re: No rpm readings
It should read the rpms from the side of the dist. Your ECM should not have been damaged.
Old May 21, 2007 | 12:33 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: No rpm readings
Hi!
I got it working today,it must have been a bad connection,sence i replaced the wires it start to work again.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Regal105
Aug 23, 2015 03:45 PM
