info on programers
Old May 22, 2007 | 04:09 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
info on programers
i am looking for programing software that i can hook up to my laptop via USB port. also if there is a program that i can use for real time stats of the car while its running. I am looking to reprogram my ecu to match the performance parts that i will be adding for max performance. any info will be helpful please add links if posable. the car is 89 iroc/tpi/map sensor
Old May 22, 2007 | 08:22 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: info on programers
if your running the factory ECM then http://www.moates.net/ will have everything you need.
if you don't have any chip burning hardware, the AutoProm is probably the way to go, it comes with a cable for data logging, a registered version of TunerPro, and can do real time emulation & burn chips.
some basics for chip tuning, https://www.thirdgen.org/promintro
for more info on chip burning read through the stickies in DYI PROM,
https://www.thirdgen.org/forums/diy-prom/
Old May 25, 2007 | 02:55 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
sweet thanks that will help a lot
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
