Piggy Backing ECM's
Old Jun 20, 2007 | 09:51 PM
blander66's Avatar
Piggy Backing ECM's
I am looking into switching to a MegaSquirt becasue im going to be adding boost to a engine and want to keep the electronic transmission controals. I know i can run two ECU's but the big question is how do i feed both the ECU's signals that they both require with out loosing signal quality while spliting the signal
Old Jun 20, 2007 | 09:59 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Piggy Backing ECM's
What transmission controls are you talking about???
What kind of car do you have?
The f body cars do not have an electronic transmission. The only electrical requirement is for torque convertor lockup, and the megasquirt can handle that and much more.
Old Jun 21, 2007 | 05:52 AM
blander66's Avatar
im looking to control a 4L60E, i know this is not stock stuff but what im building no where near stock
Old Jun 21, 2007 | 07:49 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
You could use a NPN transistor to amplify the signal. Please bear with my bad art.
Code:
5 volt source-->N P N--->to both ecm's
            from dizzy
On a side note...if your willing to wait a few months, the GPIO board will be available for the Megasquirt. It'll control your 4l60e, and just about anything else you could imagine. That'll save the headache of piggy-backing.
Old Jun 21, 2007 | 09:13 PM
blander66's Avatar
ok when using a transitor to amplify the signal im still having to split the wires to i simply just put a splice in and make one wire go into two or do i need to then amplify each signal
Old Jun 22, 2007 | 12:34 PM
pizza_guy's Avatar
I would initially try it without the amplification at all. There is a chance you won't even need it. IMO, at the most, you'll only need to amplify before splitting the cable.
However, a little overkill won't hurt anything, and if you're willing to spend the money(quite a little in this case) and time to amplify after splitting, it wouldn't hurt anything.
86IROC112
Aug 21, 2015 07:20 PM
355tpipickup
Aug 19, 2015 10:02 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
