Speedo is correct but ECM says 0 mph?
Old Aug 18, 2007 | 01:03 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
I've got a 92 formula, was a LB9/T5 car, dropped in a 350 and did a t56 swap. Did a little chip tuning to make the speedo read correct, but When I'm datalogging it always shows the vehicle speed as 0. Everything else looks and acts normal. Anybody ever seen this kind of stuff? I don't know why I can change the VSS pulse divisor on the chip to correct the speedo on the dash, but it won't show speed on the computer?
Old Aug 18, 2007 | 08:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Speedo is correct but ECM says 0 mph?
There are two spots that need to be changed in the chip to make it work. I dont remember exactly what they are, but a search of the DIY PROM board and/or the tranny forum should find it for you.
Old Aug 19, 2007 | 07:04 PM
Car: 1991 Camaro RS
I believe those would be (as displayed in tunerpro rt) the Vehicle Speed Sensor (sets how many pulses per mile as calculated in the ecm) and switch 18, bit 6 (should toggle between optical and magnetic vss). I've played around with both of them a little bit, but didn't have any good results. I should have put that in my initial post (sorry 'bout that!) Since I did what I could find in the tune, I was wondering if it could be a problem in the wiring, or maybe something in the ECM itself or in the VSS buffer.
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
Regal105
Aug 23, 2015 03:45 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
