CODE 44
Old Aug 31, 2007 | 10:05 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
CODE 44
my car has been giving me problems with the engine. so i did a code check on it and i found a code 44: lean exhaust in the Haynes Repair Manual.
Code 44 says,
Lean condition caused by malfunctioning carburetor/ fuel injector, vacuum leak, low fuel pressure, etc.; poor electrical connection, open or short in circuit; defectiv MAP sensor; Defectric oxygen sensor; defectric ECM.
has anyone else has this code before?
i check the vacuum leak and found nothing.
i replaced the MAP sensor. it semi fixed it, where is the oxygen sensor and how do you test it if its good or bad? im running a 1990 RS, 305 TPI engine.
oh also how do you tell if you got a bad fuel injector?
oh i forgot to tell you what problem im having.
it spudders when trying to accelerate. like its not getting enough gas. seems like its miss fireing kind of thing happening.
you know when you try to accelerate with to high of a gear and it just spudders. lets say your in 4th gear when you should be in 2nd? that kind of thing. accerating is horible until you get to about 3500 rpm and up. it starts going pretty good.
after replacing the map sensor it fixed it abit. its not as bad but it still runs terrible
Old Sep 1, 2007 | 12:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: CODE 44
Sounds like a bad fuel pump or clogged fuel filter. That will ause both the code 44 along with the driveability issues you are experiencing.
Check the fuel pressure at the rail, TPI with the vac line off should be around 43.5 psi. May need to check this under load.
RBob.
Old Sep 1, 2007 | 03:22 PM
joshh44's Avatar
Engine: engineless
Re: CODE 44
sorry i got confuzed im running a 305 TBI. and i changed the MAT sensor not the MAP sensor.
i changed the fuel filter and still running terrible.
im hoping its not the fuel pump. dont really wanna have to change it out.
Old Sep 2, 2007 | 06:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: CODE 44
No problem, athough it still sounds like a fuel pressure issue. The TBI's are 9 - 13 psi for service specs. Unfortunately, there isn't a port to measure the pressure. Need to open a line and put an adaptor in place. Easiest is at the frame to engine lines under the hood. The larger diameter line is the one to check.
RBob.
Old Sep 2, 2007 | 08:03 PM
joshh44's Avatar
Engine: engineless
Re: CODE 44
oh ok thanks for the info.
ill check it out and see what its at.
Old Sep 8, 2009 | 09:10 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
Re: CODE 44
still have this problem? try this out. " possible air solenoid stuck in upstream position blowing air in ahead of 02. With engine running & fully warm, pinch off hose from air pump to exhaust manifold. Scan 02 volts & integrators for change." MY friend had similar problem like u and was sending out a code 44. he disconnected the hose and the problem went away
nevermind this is an old post.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
