Tell me what you think of my TTS datamster for my 93 LT1.
Old Oct 1, 2007 | 01:55 AM
Steve40th's Avatar
I think I may have a O2 seeing a lean condition on the left bank. I took 2 long logs to see how things would play out then I VEMaster'd teach run to the 2nd run to see if it changed anything.
File Type: zip
File Type: zip
Old Oct 1, 2007 | 09:24 PM
Steve40th's Avatar
Re: Tell me what you think of my TTS datamster for my 93 LT1.
Can O2 sensors cause this? I went from non heated to heated O2's and a DELTEQ igintion system. Didnt run like this before those items, and Wideband shows 14.2-14.5 at cruise and 13.1-12.7 at WOT. Wideband is in right pipe behind header collector.
I just looked at the plugs, all were a very light tan, with no indication of pre ignition, based on many years of looking at plugs and pretty pics on the net to help.
All the header gaskets are clean, as no evidence of exhaust leaks, no burn marks etc and headers are coated and I see no leaks that are evident.
The left O2 sensor, AC Delcos, was a tad, about a mm loose. I dont know if that is enough to cause a leak, but it was there.
Old Oct 2, 2007 | 09:43 PM
Steve40th's Avatar
Okay, Last try
Here they are in Excel.
http://www.mediafire.com/?35gzczdy222
midge54
Sep 2, 2020 07:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1 DwnCam
Southern California Area
Aug 5, 2002 01:42 AM
davidjon_99
Oct 6, 2001 11:49 PM
