Running Lean?
Old Oct 4, 2007 | 08:47 PM
DirtyracingGTA's Avatar
Axle/Gears: GM 9-Bolt
Running Lean?
Hey guys got a question I checked out my car with the OBD1 and my car read lean, is there someway i can change that?
Old Oct 11, 2007 | 09:58 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Re: Running Lean?
Add fuel??
I assume you mean to say there was a lean condition code stored? If so, there is either a vacuum leak somewhere, letting in unmetered air, or you have a fuel supply issue.
Checking for a vacuum leak would be easier, with the engine running, spray some brake clean around the engine. This will get sucked into the engine if there is a leak and cause the idle to change, you'll know it when it happens. The brake clean will quickly evaporate, so you don't have anything on your engine when you are done.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Street Lethal
Aug 14, 2015 08:25 PM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
