Help With Codes
Old Oct 8, 2007 | 12:10 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Help With Codes
I keep getting the MIL after the engine is warmed up and cruising at highway type speeds; 45mph-up. I finally got a chance to pull the codes: 13 & 15 which are "Oxygen Sensor signal stays lean in warm engine cruise" and "Low temp indicated at coolant temperature sensor".
I can handle these two issues myself, but mainly I was wondering if they could be related? Could a bad temp sensor interfere with the O2 signal or anything like that?
Any info is appreciated!
Dave
Old Oct 8, 2007 | 03:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Help With Codes
Yes, if the computer thinks the engine is too cold, it wont run the proper checks on the O2 sensor, so it will run in open loop mode.
Old Oct 8, 2007 | 05:06 PM
Big Dave's Avatar
Re: Help With Codes
OK. Thats what I was thinking.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
