2 MAFs... is it possible?
Old Nov 25, 2007 | 06:05 PM
beatercoprice's Avatar
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Is it possible to wire up 2 MAFs to a 16197427 PCM or wire them together somehow?
Old Nov 25, 2007 | 07:01 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: 2 MAFs... is it possible?
why would you want to
Old Nov 25, 2007 | 08:01 PM
Engine: L05's
I'd like to retain my stock airbox look, but slightly modified. The modification looks stock but flows more air, requires two air inlets to the air box. If someone is running a MAF two air inlets can be a problem.
Old Nov 25, 2007 | 10:39 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It could be done, but it would require that both MAFs be read at the same time as well as an additional output would be taken up. Not real easy.
Easier to just go with a single inlet and an airbox from another car. With MAF, all the air entering the engine must pass through the MAF, so a dual inlet system wont work unfortunately
Old Nov 26, 2007 | 01:12 PM
subliminal's Avatar
If you want a dual intake and have a MAF you have to set it up like this..
Old Nov 29, 2007 | 05:51 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Dimented:
I had thought about this before, couldn't you just rescale the tables?
The MAF would see 1/2 flow so scale accordingly, the second maf need not
be hooked up, but used only as a restrictor so they both flow the same?
Old Dec 20, 2007 | 05:24 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Running one as a simple restrictor sounds good, but it'll introduce inaccuracies into the fueling which could cause major drivability issues.
I can see how it would be possible with some work on the programming, but without changing the operational code in the ECM I don't think it would work well at all.
suh_wheat_86305
Fabrication
Sep 12, 2007 05:38 PM
