another ecm question
Car: 84 z28
Ok. I'm debating on pulling the ecm and all the wires with it out (went to a carb) just want to know exactly what I need to leave. And what I cant pull out
Car: 1989 Camaro
Engine: 383
Re: another ecm question
I thought 84 Z-28 were carbed. anyway, just make sure you leave the wires that go to the instrument panel so you will ahve tach, volts, oil pressure,and temp. Other than that you just need a wire from the key switch to the distributer.
