Engine surge in closed loop
Old Jan 27, 2008 | 06:20 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
My 95 LT1 engine surges when in closed loop and I can not figure out what is causing it. I have checked near every thing a couple of times now and I stillo can not find what is causing it. When it surges my wideband says that it is bouncing lean, but when I unplug the O2s and force open loop the the car runs great. So what sensor could cause this in closed loop?
I have already:
replaced opti with complete MSD
replaced both O2s
replaced map
checked plugs and wires
checked for vacuum leaks
checked for exaust leaks
replaced icm
checked the coil
Old Jan 29, 2008 | 08:53 PM
Car: 1987 firebird
Transmission: 4l60e
Re: Engine surge in closed loop
Any Ideas?
Old Jan 30, 2008 | 08:19 AM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
First stop throwing parts at it....save yourself from the poor house!! K.I.S.S. the situation...how about the following:
-Closed/Open loop happens by the thermostat heating up and opening in junction with your temp. sensors...that info is fed to the computer.
-What is your temp gauge reading?
-What is the scan tool( if u got one) reading for engine temp?
-Have you tuned/flashed the ecu lately?
-Will this surging happen after car is fully warmed up or after some hours of driving?
...when you say "surge" what exactly happens...idle get rough....car stumbles like a dead cylinder....rpm hunting??
check engine light...pending codes??
Last edited by AMigs87IROCz; Jan 30, 2008 at 08:20 AM. Reason: Automerged Doublepost
Old Jan 30, 2008 | 11:20 AM
Car: 1987 firebird
Transmission: 4l60e
The car was tuned by PCMforless and it starts rpm hunting the second it hits closed loop. I can watch the tach bounce a couple hundred of rpm, and when driving it wants to die at stop lights, when shifting gears, and I can feel it when driving at a steady speed. My Wide band says that it bouncing lean when it surges. This does not seem to be temperature related, it does it cold or hot the second it hits closed loop. And from monitoring my scanner and temp gage my car consistently runs at 180 with a 160 thermostat but I am unsure at what temp it goes into closed loop.
And like I said if I keep the car in open loop it runs great.
Old Jan 30, 2008 | 11:27 AM
Car: 1987 Iroc-z
EGR valve? My camaro did that...I couldn't differentiate if only on closed loop but my surging and stalling at idle was my EGR valve not doin' its job...have you tested it?
Old Jan 30, 2008 | 04:47 PM
Car: 1987 firebird
Transmission: 4l60e
The EGR has been deleted and programmed out, at least PCMforless should have.
Old Feb 1, 2008 | 11:41 AM
Car: 1987 firebird
Transmission: 4l60e
Some other guys VSS post remined my of something about my car. After I stroked my LT1 to a 383 and had the computer reprogrammed by PCMforless it gave me code 97 (VSS ouput low)? I tried a new VSS and still the same problem? The only other thing that I could think that would effect this was the output shaft, since I just rebuilt the tranny and cryoed the output shaft. But everyone assured me that it would not effect the VSS. So I ended up sending my computer back to PCMforless and having them delete code 97 from my computer.
Could this be causing my hunting or surging in closed loop?
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
