Code 45
Old Jan 29, 2008 | 08:27 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
Code 45
I just got done spending a week or so tracking down a problem (engine would cut out intermittently) only to have to bring it to a shop and get charged up the @$$ for it.
Turns out I had a bad MAF and the oxygen sensor was shot, so I had those replaced.
I'm beginning to hate computer controlled cars at this point (which is why I have a '74 Nova in the garage )
Just tonight on the way home, I was cruising down the road at a stead 40mph and looked down to see the SES light on. I wanted to shoot the friggen thing.
Get home, check codes, spits out 45.
The other day I got a random code 32 (?!?!?! The MAF is brand spanking new???) I cleared it and it hasn't returned (yet...)
Sooooooooo considering the MAF is new and the oxygen sensor is new, along with:
Wires
Cap
Rotor
Plugs (about 20,000 miles old)
Tuned TPS (.54v)
What else could be the problem? I know I need to check for fuel pressure, but shouldn't the tools (and I mean people) have noticed anything the first time I had my car in?
I almost can't wait to save up the money for the rebuild on the Nova, It seems like the older they get, the easier and better they run!!!
Old Jan 30, 2008 | 08:28 AM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
Re: Code 45
Oh holy hell-You know what I did after seeing code 32 a few times?!?!I converted my ecu/tpi to speed density. F*CK MAF....that sensor is SOOO picky if your running K&N filters...the slightest crap will pop the sensor...also if the connections running to the MAF are even the slightest corroded it will throw that code(toward the end I would see that code and have to wire brush and clean the connection.) That was getting soooo rediculous for something stupid...I couldn't take it anymore!! So I and then did the conversion. Good riddens!!!
As far as the ses light....I've got a 87...so I dunno
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
