LT1 nearly stock.. convert to Megasquirt general questions
Old Feb 14, 2008 | 05:54 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Anyone have any success stories with Megasquirt and the LT1?
I am close to buying a DIY Megasquirt I V3.0 kit. Thinking I will manage the spark with a Ford EDIS and a 36-1 crank trigger. Doing this I think I can bypass the Opti altogether. the motor is a 96 so there is a crank trigger but from what I have read, it is nearly useless with the megasquirt as it doesn't have the resolution needed. Truthfully I would much rather see a set of LS1 coils and gear rather than the Ford stuff, but Ford seems to have a nifty package there.. hard to resist.
I have a couple of questions..
Where am I to secure a 36-1 crank trigger/sensor to fit a GM crank?
Any better idea than the Ford EDIS? I already have the EDIS(freebie)
Is the LT1 bank fire or sequential? currently im running on a 94OBDI ECM
to eliminate the stock ECM .. I will need the SGI-5 Dakota Digital box.. which I own.. that will provide my correct speedo signal from the T56 .. but would wokr for T5 etc.. Not sure what people would do for the Autos... buy a clutch pedal i guess.. haha
Old Feb 20, 2008 | 09:25 PM
Deaclen's Avatar
Car: 91 camaro Z28
Engine: LT4 Intake & Heads bottom end 94
Re: LT1 nearly stock.. convert to Megasquirt general questions
Thirim, I have thought about doing the exact same thing. I have thought about several different options and still working on the logistics. I have not done enough research to know yet and I won't know without that research but here is my idea:
Megasquirt system using the MSD crank trigger with the DIS4 and have that power the coils. I would still only get four coils unless you split it off and did like a bank fire instead. My engine is a 94 and does sequential. Now you can probably tell me if this will work or anyone else. I never said it out loud and didn't want anyone saying you retard you can't do that. But anyway... I do recall that 92-93 they used bank and 94 is the switch over year to the sequential fire. You can also find the 36-1 crank trigger/sensor on ebay and then either weld it on your harmonic balancer or make a mounting plate like a buddy of mine did for his V6.
Old Feb 20, 2008 | 11:00 PM
Firebat's Avatar
This guy has done the megasquirt in an LT1 and completely eliminated the opti. http://brian-esser.com/?page_id=24 Someday I plan on just eliminating the high spark through the opti and use coil packs. However, i'll still keep the pcm and use the opti for fuel injector signals, unless i learn megasquirt.
Old Feb 24, 2008 | 11:36 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
ok. I ordered up a MS1 V3 kit..
Still not sure how to mount up the trigger.. I guess im going EDIS ... will be looking for a non opti timing cover.
thanks for the info!
anyone with crank trigger input?
Old Feb 24, 2008 | 09:00 PM
Brian Esser's Avatar
Car: 1996 Chevrolet S10
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Thats my old site. I have since moved it to http://www.projectlt10.com
I haven't had a chance to update it for awhile as I am still waiting for my shop to be built. But, i will be glad to answer any questions as well as lend assistance or suggestions.
Megasquirt with the additional I/O board can do sequential. However for the added benefit I don't think it's worth the hassle. True sequential does improve idle quality and throttle tip in. But, batch fire works more than fine for 99% of the engines out there. As for the igniton side of it. I have seen possible workarounds for using two EDIS4 systems together on a V8, but i don't recall seeing any actually running.
The MSD crank trigger will not work with the EDIS system. it relias as already stated on the 36-1 toothed wheel for it's reference. The MSD trigger will work with the Megasquirt though if you had a different ignition setup. I used a crank trigger from http://www.diyautotune.com after trying several triggers (I'm picky lol).
Here is some background information about Fords EDIS system as well as how I used it on my 94' LT1. http://projectlt10.com/edis.php
I modified my setup though and decided against using the Ford 4 tower style coils as the wirse required for such towers are expensive and not readily available as standard end plug wires are.
Here's some photos of my engine, though these were taken last summer.
Old Feb 24, 2008 | 09:07 PM
Deaclen's Avatar
Car: 91 camaro Z28
Brian, thanks for the info on the MSD crank trigger. I knew it wouldn't work with the EDIS system. I just don't like the idea of putting Ford parts on a Chevy vehicle. Seems very evil to me and gives a cold shiver. LOL! You have a nice setup and actually gave me an idea of where to put my Coil packs when I get the setup built. I believe now since you managed to answer my question I think I can use the MSD DIS4 for my ignition with that crank trigger. According to MSD tech they should work nicely together.
Question? In your last picture there you have your MAP but no wiring. I think I see some wiring or are you still putting this Bad Larry together?
Old Feb 24, 2008 | 09:18 PM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Actually. That MAP sensor will be removed and a cover plate made. The Megasquirt has it's MAP mounted directly into the ECM itself. So I won't need the stock one in the stock location. I have a vacuum line ran into the cab where the ECM is.
The DIS4 system is very nice! I used it on a Cavalier with a warmed over 3.1 in place of the 2.8 and it would easily walk a 305 F body. However it also had a Holley C950 ECM and some other mods done to it.
Old Feb 25, 2008 | 01:01 PM
Firebat's Avatar
Brian - What would be the estimated cost to run coil packs in a LT1? Estimated cost to run coil packs and megasquirt computer? I would try to get used parts off of ebay.
Old Feb 25, 2008 | 04:07 PM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
The Megasquirt will run you anywhere from $240 to $430 depending on which variant you choose. I would go with the latest pcb version and the MS2 processor. The MS harness will run you around $60 for a 12' harness. You will need all the sensor plugs depending on which sensors you use. Megasquirt is cool cause it uses GM stuff, and readily available stuff at that.
Here's the sensors the Megasquirt uses.
Coolant Temp Sensor (tuneable to nearly any sensor out there)
Throttle Position Sensor (tuneable to nearly any sensor out there)
Intake Air Temp Sensor (tuneable to nearly any sensor out there)
Manifold Absolute Pressure Sensor (mounted on PCB in MS unit)
Oxygen Sensor (can use either narrow or wide band)
The coil packs brand new are around $20 a piece, however most junkyards sell them for a few bucks a pop. I have a ton of them laying around from vehicles I've stripped over the years, so they cost me nothing.
The EDIS8 parts can be found at most yards. I spent about $50 for the EDIS8 module, and the VR sensor and pigtails. I didn't bother grabbing the coils as I knew I wasn't going to use them. Expect to pay upwards of $100 for the coils, module, vr sensor and pigtails. That will vary depending on the yard, and your location too. You can get all the parts used online as well from various sources. http://www.diyautotune.com is selling very nice trigger wheels now as well. The VR sensor bracket and mounting the trigger wheel, will of course depend on your engine and setup and space constraints.
So if you are starting out with no MS unit and no EDIS parts, expect to pay anywhere from $400 to $600 for the setup. Of course that can be almost cut in half if you find donor vehicles or score the EDIS parts for free etc. Be carefull buying MS units from Ebay and private sellers. I've seen several people burned by buying MS units that weren't assembled correctly or were fried. I highly recommend DIY Autotune (http://www.diyautotune.com). I've literlly spent thousands with them and they have always been on time and gave me great service. There are several dealers who sell fully assembled MS units.
This is taken from my site regarding finding EDIS parts for others who are looking...
Finding Edis in North America
If you go to a salvage yard for EDIS modules, they are usually located in the engine compartment on the driver's side inner fender. The modules have a EDIS-4 (or EDIS-6 or EDIS-8, depending on number of cylinders) sticker on them. Try to take the connector as well, as well as the ignition coil pack(s) and connectors. You can also obtain used units from the salvage web at www.car-part.com.
The EDIS can be found on:
  • EDIS-4, 1990 to 1993 1.9L 4 cylinder engines,
  • EDIS-6, 1990 to 1995 4.0L 6 cylinder engines, and
  • EDIS-8, on 1990 to 1997 4.6L V8 engines.
The EDIS 4 and 8 cylinder coil packs are available from Accel under number 140018 ($54.95 each from Summit Racing)
The 12 pin connector for the module is available through http://www.napaonline.com/ and has the part#ECHEC172 and runs $25.99. The coil pack connectors also available through napa have the part# ECHEC259 and run $18.49 for a pair.
Early to mid 1990s Ford Escort/ Mercury Tracer with base 1.9L SOHC engine were fitted with the EDIS4 system. You can tell the engine because it has a tubular aluminium (NOT cast) inlet manifold.
The EDIS4 module is mounted just behind the fuse box on the drivers side of the engine bay, it has a label on the plug that says EDIS4. The bolts are 10mm AF. You are advised to remove the fuse box first for easier access. Cut off as much as the harness as you can.
Looking toward the passenger side end of the engine, the VR sensor is above and to the left of the end of the crankshaft. The easiest way to access the sensor is to remove the front wheel (if it's not already removed), lie on your back, and reach up from the bottom to access the sensor mounting bolts. The bolts are either small metric or star bit. Once it's off, the cable is most easily cut from the top.
The crank pulley bolt is 19mm. You will need to stop engine from turning, various methods have been suggested. 1) remove the head, put some rocks into the bore and refit the head. 2) remove a spark plug and put a long bar down the hole 3) remove a plug from cylinder with piston at BTDC and coil in some rope, remove rope when finished.
For the rest of it, check out http://projectlt10.com/edis.php
I've pretty much scoured for all the EDIS info I could find and tried to gather it in one place and have it make sense. If anyone finds any errors please let me know, or if anyone has any additions I should make.
Old Feb 25, 2008 | 06:27 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
+1 for DIYautotune. They were a great help for me. I am not running anything as exotic, but the MS does run the stock 8 pin module very well.
Old Mar 2, 2008 | 09:09 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
i have a few questions? let say you convert you system how do tune for a normal LT1 tune without going to a tuner and dyno it? How do you get the gauge cluster to work with the megasquirt? A/C?
Old Mar 3, 2008 | 07:12 AM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
thats what makes megasquirt a slight challenge for the novice not familar with EFI and tuning. You must tune it yourself and as for finding the optimal setup, most take it to the track and let the ET's tell them if they are making more power. Others get it close and call it quits. But, again it depends on your knowledge of EFI and basic engine and tuning principles.
As for the gauge cluster, most guys piggyback the MS on top of the stock ECM letting the stock ecm control the trans and gauges while the MS controls fuel and spark.
Old Mar 3, 2008 | 07:45 AM
Toehead's Avatar
If you replace your current ECM, you dont need to change the gauges.
I removed my factory ECM and replaced it with the megasquirt. All of my gauges work fine.
You may have issues with the speedometer depending on if the ECM buffers the signal, but I think you will be fine. Unplug the ecm and roll down a hill to test
As for the tune...
The Megasquirt is speed density, and relies on a volumetric efficiency table. If you can get a table from a stock bin, it will give you a baseline.
Old Mar 3, 2008 | 10:04 AM
KBcobra's Avatar
Engine: 3.1L V6
What about a/c?
Old Mar 3, 2008 | 11:56 AM
Deaclen's Avatar
Car: 91 camaro Z28
A/C on the LT1 is not controlled by the computer to my knowledge. I just wired it into my Thirdgen wiring when setting up my LT1 to run in my Thirdgen and I don't recall it having to do anything with the PCM. Plus on the Thirdgen it isn't computer controlled anyway aside from when it kicks on it raises the idle a bit if I remember correctly. But, I have been known to be wrong.
Old Mar 3, 2008 | 10:34 PM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
You are correct
Old Mar 5, 2008 | 06:49 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I just need to know what powers the megasquirt. Oh can anyone tell me the fuel pump relay thing. How did you wire urs? Im almost done with it. lol and im so anxious
Old Mar 5, 2008 | 08:03 PM
Toehead's Avatar
The power wire powers the megasquirt?
Just use the stock power for the ECM.
It needs to be hot in crank and run and not hot with ignition off.
ezobens
Aug 19, 2015 10:29 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
Thirim
Aug 13, 2015 03:09 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
