Ford EDIS with GM ECM?
Old Feb 25, 2008 | 04:05 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I've been researching what all is required to install megasquirt, and so far the only real advantage I see over tuning the GM ECM is the ability to easily set up distributorless ignition, using a ford EDIS ignition module. It is not coil-on-plug, but uses coil packs, 4 of them for an 8 cylinder engine. It uses the 'wasted spark' method, which means that 2 plugs fire at once. This method does not need a cam position sensor, only a crank position sensor. I know I could add a crank position sensor without too much trouble, but I'm wondering how hard it would be to make the factory ECM control the EDIS module. It has 2 data wires, one for the ECM tach input, and one for the ECM advance control. The tach signal is a +5V squarewave, and the advance from the ECM is a +12V squarewave. I'm not sure how a GM ECM tells the ignition module to advance timing, is this even close? Most of the EDIS info I have found here:
http://www.megamanual.com/ms2/EDIS.htm
If this isn't feasible, are there any aftermarket options for something like this? I found a little bit of info on modifying an optispark setup and using an LT1 ecm, with LS1 coils, but that sounds like more trouble than it's worth.
Old Feb 25, 2008 | 06:19 AM
Brian Esser's Avatar
Car: 1996 Chevrolet S10
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Re: Ford EDIS with GM ECM?
Have you looked into the megajolt setup?
http://www.autosportlabs.net/index.p..._Users_Welcome
It allows 3 diminsional timing programming and works with the EDIS. You would have to keep the opti in place to simply provide ref to the stock ECM.
You would have full tunability and it would work with the stock ECM.
Old Feb 27, 2008 | 01:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I was thinking of a TPI ECM though, not LT1. I don't think I could put an opti on a gen I motor without significant mods, right?
Old Feb 27, 2008 | 03:26 AM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Though I suppose it would be possible if you had your own machine shop and an unlimited budget. But, the Opti isn't worth the hassle.
A TPI ECM would work with the Megajolt just fine.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
