Megasquirt isnt blinking
Old Mar 13, 2008 | 08:18 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I know I have power going to it, but when i turned the ignition on to prime the fuel pump, I got nothing. I have not yet hooked it up to the computer to tune it. Is this why? I thought ity would at least blink though. Im just checkin that Im good so far
Old Mar 13, 2008 | 11:11 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Megasquirt isnt blinking
I would double check the power connections, and also follow the megamanual.
You may need to manually load the firmware onto your unit.
Old Mar 13, 2008 | 11:59 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I think I may have to. I think the firmware could be bad. I mean i know I have power now. The laptop shows tps working and all.
I checked the fuel pump wire and no power goes to it. Anyways I think I may do the firmware thing. I gotta look up how to do that one lol
Old Mar 14, 2008 | 12:03 AM
dayton's Z's Avatar
Car: 85z-28
Engine: gm goodwrench 350
Transmission: t-5
Axle/Gears: stock, 3.08 one wheel peel!
did u build it yourself of buy it? did u go thru step by step and set up all your initial settings yet from megamanual? what relay are you using, the relay board in the megasquirt or an external relay?
Old Mar 14, 2008 | 01:32 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay I bought a predone one from DIYAUTOTUNE. I also bought their wiring harness. What else besides wiring everything together correctly should have i done? They also preloaded the 2.68 code onto my ms II.
with that preloaded it should at least prime the fuel pump right?
Old Mar 14, 2008 | 06:08 PM
Toehead's Avatar
You do know that the fuel pump output supplies GROUND (not power) right?
Old Mar 14, 2008 | 10:27 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ya i heard supposedly its best to run the relay wire from the ms to the wire of the fuel pump relay like where it begins. the fuel pump relay wire is the tannish one with a white stripe right.
Jk_Under
Sep 2, 2015 10:59 PM
Thirim
Aug 13, 2015 03:09 PM
86bird_28v6_5spd_ramair
Aftermarket Product Review
Oct 13, 2001 09:57 PM
BahamutRS
Sep 15, 2001 02:51 PM
